Agile downloading via wap
5 replies · 1,798 views · Started 19 May 2006
is there any1 who knows how i can download agile messenger or turbo or any other IM that uses msn on to my nokia N70, i've tried various sites and when its on the installation part the screen says security error unable to install, is there anyway that i can change the settings if any1 knows please help
Cheers in advance :con?
Wirelessly posted (NokiaN70-1/2.0536.0.2 Series60/2.8 Profile/MIDP-2.0 Configuration/CLDC-1.1)
Hi even you downloed the agile messenger it's not working no nokia N70 because i install it.but it didn't work 😊.
Hi even you downloed the agile messenger it's not working no nokia N70 because i install it.but it didn't work 😊 if you want to try in to the sitting and aloud the lava scrip to work.try
Wirelessly posted (NokiaN70-1/2.0539.1.2 Series60/2.8 Profile/MIDP-2.0 Configuration/CLDC-1.1)
naycy wrote:Wirelessly posted (NokiaN70-1/2.0536.0.2 Series60/2.8 Profile/MIDP-2.0 Configuration/CLDC-1.1)
Do u know of any other java or symbian applications and where i can download them from but this has 2 b done via wap 😊
