Do you have either Outlook 2002/2003
1 replies · 2,091 views · Started 19 May 2006
I would like to run a little experiment with someone who has either Outlook 2002/2003 using a N70/N80 what I would like to know is if you colour code an appointment in calender does it show the same colour triangle (month view) on the phone. I expect I'm being a bit optimistic hoping it will be colour cordinated on the phone.
Unfortunately I can't test this myself as I only have Outlook 2000 but if it does then I will upgrade to Outlook 2003 as it would be useful for my shifts. Thanks in advance.
Andy
Simple answer is don't think so.....I have had a look and the current month has a Green Triangle and the other Months had Yellow where there are appointment for that day.........
