Where can I find compatiable software for my N80?
Software must be S60 3rd Edition / N80 compatiable if it comes as a .sis file (i.e. native application). Java programs (.jar) files should install, but may not work fully (entirely dependent on program - a common issue may be not using the full screen or fonts being too small).
You can find a list of software for your phone here:
http://www.allaboutsymbian.com/software/Nokia_N80/
Help I'm having trouble installing .sis files
If you are having trouble installing programs (.sis files) you need to make sure that they are compatiable (S60 3rd Edition / N80) and you need to make sure you have the settings in your phone configured to allow software installation.
In App Manager go to settings and make sure 'Software Installation' is set to All and 'Online cerif check' is off.
Note some have reported variations on this dialog (e.g. Options -> Defintion -> Allows software install -> set yes). The tick is to make sure software installation is set to yes.
Phone tries to install program at startup but fails, try to install again at next start up.
If you go to the Manager applications (found under Tools) you get a list of installed applications and available installation files. You should be able to install the files your phone is trying to install from here (if you have problems check you have the settings correct to allow software installation) OR you can delete them.
At a guess I would say it is programs like Catalogs / Mobile Search / Nokia Games etc. that the phone is trying to install for you.
If you've got nay helpful suggestions / feedback about these issue please add them below 😊
hiya mate, ive just got my n80 and i want to run tomtom on it. I have beeing using tomtom on my 6680 via a .sis file. When i put this software on the external memory and try to install it doesn't work cos i presume its a different os is there anyway of convertig cheers bud
Can anyone tell me if FExplorer or AppMan are available for 3rd series symbian phones yet? I used then lots on my other series 60 phones and I miss their functionality.
I have SExplorer, but it won't let you do stuff with the files, just look around a bit. 😊
Dayzee
xx😊
No FEXplorer and Appman are not available yet.
Check out this - http://www.allaboutsymbian.com/software/item/Best_TaskMan_for_S60_3rd_edition.php
for similar rufnctionality to appman
I have a problem with my N80 phone. My phone always auto Off and On (restart) during open menu for 5 or 10 minutes like I open the picture, video clips, type message,.... why???
Anybody can help me?:con?
hello everybody, i'm new here,
I've got a n80 since yesterday.
can anybody tell me step by step how to get wifi working?
can't find it in the user guide.
greetings
best site i have come across is www.series60v3.com
simmatt wrote:best site i have come across is www.sereis60v3.com
best site is you want a load of adverts all over the shop!¬
well lets see,
hav lots of free games like me and put up with the adverts, or pay for your games, hmmmm, think il pick to put up with the adverts
and also the like is www.series60v3.com, made a mistake in old link
Rafe wrote:
[B]Help I'm having trouble installing .sis files
If you are having trouble installing programs (.sis files) you need to make sure that they are compatiable (S60 3rd Edition / N80) and you need to make sure you have the settings in your phone configured to allow software installation.In App Manager go to settings and make sure 'Software Installation' is set to All and 'Online cerif check' is off.
http://www.allaboutsymbian.com/forum//forum/thread/49710/nothing of these works on mine N 80
im totaly ..&*#% 😞 i want Smartmovie but it wont install .. certificate i tried all (and many reboots) but nothing works!
I have only had my N80 since Friday, but I have spent more time with Nokia Help Desk than I have using it. Looking for a book reading application with a sis extension. Am told Mobipocket has one but the N80 wont accept any of the ones Ihave tried. Any suggestions please. I thought Symbian was compatable with Mobi, but we know what thought did!
Any helpful info would be appreciated.
Salamanader
مشكور لخوي على المهوووووووووووووووووووووووووووووووود😮 😮 😮
Very great thank everyone for the messages
