does any1 know of anysites that i can download any of the various IM services for my N70 i've tried agile messenger and turbo and the versions i'm getting are not being allowed to transfer on to my phone can any1 help as i used them all the time on my old nokia
cheers
What do you mean by not being allowed to transfer?
If you set up PC Suite and use your USB cable you should have no problems.
Rafe wrote:What do you mean by not being allowed to transfer?If you set up PC Suite and use your USB cable you should have no problems.
He's probably still got the security block turned on in 'Tools | Manager | Settings'....
Steve
slitchfield wrote:He's probably still got the security block turned on in 'Tools | Manager | Settings'....Steve
Cant find the option on that to switch the security of all i get is software installation, online certifi check and default web address i've tried various settings to try and let me download either threw my pc suite or via the wap and my phone is giving me security error how do i switch this of????
Set Software Installation to On, Online check to Off.
Steve
cheers for that steve m8 but i cant find the option where its lets me change them to that setting m8 looked on my settings etc not there
'Tools | Manager | Settings'.... as I said above!
Steve
Wirelessly posted (NokiaN70-1/2.0539.1.2 Series60/2.8 Profile/MIDP-2.0 Configuration/CLDC-1.1)
slitchfield wrote:Set Software Installation to On, Online check to Off.Steve
Steve changed these settings so that they are what u say but its still not allowin me 2 pass the security 4 some reason, so if u got any other ideas let me know as i said i've tried various settings but its stil not letting me download it on 2 my phone, i even tried downloadin on my old phone then usin my memory card in my n70 agile was the only application that didn't work on the n70 all games plus other apps worked
Steve cheers 4 ur help i've now got it workin all i had 2 do was switch my phone off and then back on this must save the settings or somethin not sure but wateva it does agile is now workin on my phone well almost jus havin trouble now gettin it 2 register cheers. Kev
