N80 and Windows 98
4 replies · 2,448 views · Started 21 May 2006
Does anyone know where I might be able to download a driver to get my Windows 98SE to recognise my N80?
Not too bothered about software etc - just want to be able to see the folders and drag and drop stuff.
Thanks,
Matt
Hmm there isn't anything for Windows 98 as far as I know. You should be able to use it USB Mass Storage mode (only access to memory card though).
You might need to find some generic USB drive drivers though. Depends on your version of Windows 98 I guess.
mattoakes wrote:Does anyone know where I might be able to download a driver to get my Windows 98SE to recognise my N80?
I remember when I first got my Nokia 7610, I had Windows ME. Apart from using a media card reader to transfer files, there was nothing I could do. Seems like Nokia de-supported all operating systems apart from Win 2000 and XP a long time ago.
I did try a bit of 3rd party software called (I think) Oxygen Phone Manager, but it was so buggy and unstable I found it practically useless. I ended up buying a new computer.
You have my sympathy, I know how you feel.
Regards
SL
