I'll probably buy a brand new v5 N70 in a few days, and with it a 1GB card. I've been offered these 4 brands of RS-DV-MMC to choose from: Kingston, Samsung, Adata or CNMEMORY.
I heard way to many bad things about Kingston + N70, so one of the other 3 will probably be the choice. Which would you recommend? I was thinking about Adata...
DoS wrote:I'll probably buy a brand new v5 N70 in a few days, and with it a 1GB card. I've been offered these 4 brands of RS-DV-MMC to choose from: Kingston, Samsung, Adata or CNMEMORY.I heard way to many bad things about Kingston + N70, so one of the other 3 will probably be the choice. Which would you recommend? I was thinking about Adata...
Adata has the fastest response times of those listed and I've had good luck with them, however ATP makes the fastest dv rs mmc to date. It costs more though.
OK then, Adata it is, as ATP I can't find.
Forgot to say I'm from Brazil, and this site doesn't ship to Brazil unfortunately =(
I've had my Kingston 1 gig RSMMC for 5 months now and I've never had any performance or speed issues...
I got mine cheaply from ebay brand new....
D
