ive just got a nokia N91, and cant for the life of me work out how to put tom tom on it!
had it working fine on my N70.
i tried just copying all the tom tom folders straight onto the hard drive but had no luck.
help!!!! please
mince
help!!!! please
mince
Have you been able to copy the system folder as well when u copied the TOM TOM from the N70? This system folder on the MMC card is not visible unless u view it via Fexplorer which is an explorer software that is better than the normal one provided.
If you are using the same MMC card that u used on the N70, then tell me what is the message that you are getting when u try to activate TOM TOM
