I managed to corrput my MMC card a while back so recently I bought a card reader to correct it. When I got it, it had different folders for different types of file. I put some music into the digital music folder and when I tested it I noticed some of the songs didn't work. Instead of deleting the songs that didn't work I just formatted the card. Now the folders are gone, my music is all fine now but I can't get the folders back, nor can I remember what they all were called and whenever I put my MMC into my phone it tells me it is corrupted despite me having just formatted it, does anyone have a solution to this problem?
MMc problems
There's a nifty program for the n-gage called "McFixer". You can get it at www.n-gage-help.com, it helped my MMC to come back to life. 😊
You have to install it to your phones internal memory so make sure you have enough space before install. After installing McFixer, reboot your phone, insert your corrupted MMC and run McFixer.
make sure you go through all the tasks in sequence, Use the wizard for easier run. You may have to repeat it as McFiXeR does not always get exclusive access to the MMC
For any other advice, use the forums from the same website where you got the program.
