I want to delete all texts from my inbox. How can i do that in one go? It used to be simple on my 6230!!
how can i delete all texts from my inbox
I think u can do so by deleting the text messages from the Microsoft windows explorer with PC suite installed on the computer (assuming you're using MS). I'm still a newbie. 😊
mviltan wrote:I want to delete all texts from my inbox. How can i do that in one go? It used to be simple on my 6230!!Go to your message inbox so you can see your message list, select options > Mark/unmark > Mark all. All your messages should have a tick next to them. Next select options > delete. This should delete all your messages at once and save you the hassle of deleting one message at a time.
S.
