*I did search the forum for PC suite and it didnt turn up anything relating to my problem.*
I have a N6680. On the first day i got my phone I installed PC Suite (used supplied connectivity cable to connect phone and PC) and all worked well and has continued to work well since. That was until i started to use a bluetooth adapter (borrowed). When using the BT adapter I used the software provided with the adapter and all worked fine. After a while I had to give the adapter back to my friend and I tried to update PC Suite. I dowloaded the new version from www.nokia.com and tried to install it. However this did not work as the PC would need service pack 1 for windows (which cannot be got due to no internet access). So... I then unistalled the attempted update and reinstalled from the disk which came with my phone. The install worked fine. BUT when i go to PC suite and try to conect my phone... its says that there are no connection options... Reinstall PC suite. So i did reinstall PC suite same problem... again... same problem! My USB cable is working fine because the phone recognizes it and USB symbol comes up. I cannot think what else could be the problem... Can somebody please give me a solution to this problem?
*Sorry for the longwinded nature of the account but i made sure i got everything in - every thing i did*
