Hi..
I copied some .midi files into my nokia 7610 from pc via USB.. But when i check my mobile for the file.. its not there atall.. Also none of the mid filesthat were present earlier in my mobile are not there. when i connect to pc, i can view all the files.. bt when i check through phone.. its not there.. can any1 help me out here
Thx
not able to play .mid files
Maybe you installed flash theme,try to delete it
Cool Man.. it worked.. thx a lot.. removed some flash appl.. thnx a lot man.. :icon14: :icon14: :icon14: :icon14: :icon14: :icon14:
