Remote desktop
8 replies · 22,664 views · Started 24 May 2006
Just got my N80 - very impressed so far.
Is there anything out there like 'remote desktop' for the N80, similar to that available for WinCE PDAs?
I use a laptop for work most of the day and it would be great to have an emulation/log in to the phone from the laptop and be able to use the keyboard/mouse/display from the laptop to drive the N80. Over wireless this would be perfect.,....
Any suggestions?
Many thanks
jc_uk
Has anyone tried this software on the N80?
If so how did it work - good, or slow?
regards
jc_uk
Hi again,
The software suggested is the wrong way round.
What i would like to do is use my laptop screen, keyboard, mouse to drive the N80...... Not use the N80 as a terminal to access the laptop.....
Any suggestions?
Many thanks
jc_uk
Wait for the next version of "Remote S60" to control the phone from the PC. To control the PC from the phone try the java VNC client j2meVNC.
Neil
You could try www.logmein.com - its a web based interface meaning you can do all the things you need whether with your phone or at a remote PC. I have it installed and it works a treat.
Interesting - I tried log me in and whilst I managed to login and could see everything perfectly, when I scrolled down to the bottom right etc. and then tried to scroll back to the top left of the screen, the screen jumped back to where I had just come from.
This made it useless for me, which is a shame as I use LogMeIn on all my servers.
I would be interested to know what settings you have on the phone and the PC you are connecting to.
For some reason, my phone comes up and says that the page requires activeX (which I know the N80 won't support) or JAVA - JAVA should be supported, but it just isnt kicking in on my N80, so LogMeIn is going to use the HTML version. Do you get this message or is there a JAVA problem on my phone?
out of interest, 'Remote Desktop' is phone TO PC not the other way round - there is a standard protocol called RDP which Windows uses, so if anyone is searching for a control system for the N80, this is not the right term.
