Nokia 6630 + Router (Livebox)
4 replies · 5,191 views · Started 24 May 2006
Hi all,
I have a router from Wanadoo called the Livebox. The device also has a Bluetooth feature. Now I am able to pair with it and really thats it. But I really want to internet on my phone through bluetooth because I know it's possible, only the problem is that I really don't know how and I was wondering if somebody could help me with this.. I already tried things with GnuBox but I couldn't do it..
Thanks in advance !
- Alex3305 -
alex3305 wrote:Hi all,
Thanks in advance !
- Alex3305 -
Have you already had a check here: http://gnubox.dnsalias.org/gnubox/ ?
cYa
Thanks in advance !
- Alex3305 -
I also suggest you to have a look at this forum: http://www.symbianos.org/yabbse/index.php?board=2 and maybe at this long thread: http://www.symbianos.org/yabbse/index.php?board=2;action=display;threadid=94
cYa
Yes I already check that out but I couldn't find anything... I thought maybe someone had some experience with connecting their 6630 (or 6680) to their router/livebox from Wanadoo..
Thanks anyway !!
alex3305 wrote:Yes I already check that out but I couldn't find anything... I thought maybe someone had some experience with connecting their 6630 (or 6680) to their router/livebox from Wanadoo..
Thanks anyway !!
Got it. I suggest you to ask in that forum anyway.
Once there was this app ( http://www.bluegiga.com/default.asp?t=1&f=2&p=null&did=91 ) but it was device dependant and n6600 only.
I personally tried the BT network profile/connection through gnubox for 6630 albeit unsuccessfully.
Take care.
