Problem With PC Suite Connectivity
1 replies · 2,445 views · Started 24 May 2006
I am not able to Connect my Phone's With Nokia Pc Suite 6.7, 6.8
I have unstall and run remover and then install i failed to use
I have attach the images
I have use three method via Usb, Bluetooth and Infrared
I use N80, Nokia 6680, N70
Three of them are not connecting
I am using DKU 2 and Ca 53
Really don't know wht has happened
Attachments: Capture_9.jpg Capture_10.jpg
You may have too many suites installed 😊
Just use the latest, I had this problem with SE phones as well.
Hth if not pm me 😊
:icon14:
