helo to everyone,
can someone pls give me the steps on how to format and reinstall the softwares to my communicator. how will i know if my software from my cd is compatible to my communicator, pls help. my unit version is 5.34. tnx
step by step on how to format and reinstall software.
Formatting the MMC:
Open file manager, MENU, MEMORYCARD, FORMAT
Once your MMC has been formatted, remove the battery from your 9210, replace battery. After about 3 seconds (before startup logo appears) press CTRL&SHIFT&F, this will bring you to the format screen. This may take a few tries as the timing is hard to do.
Select format.
Connect 9210 to PC and reinstall the 2 main Nokia .SIS files (Allnokia9210adat and allnokiammcdata).
REMEMBER TO BACK ANY DATA YOU NEED FIRST.
Regards
I always sugest to make a backup after a clean Install.
This will save some time and you will be shure that you haven`t missed anything in your inslatation.
ok thank you very much guys.
if i already back up my files, do i have to install the two .sis files? or just restore the last backup from the pc?
[quote="bry"]ok thank you very much guys.
if i already back up my files, do i have to install the two .sis files? or just restore the last backup from the pc?[/quote]
Never needed to backup yet, but normally you won`t have to install again.
Tip:
If you are using Outlook, do the backup after sync with outlook. In this way you can win +60 minutes needed for contacts.
(Or save contacts.cdb) 😉
