Yes all the time freezes and i have no idea what to do ....Do u have this problem and what can we do about it ?
my n91 freezes
[FONT="Arial"][SIZE="2"]i also have the same problem.. n91 freezing most of the time.. it seems that its' multitasking processor or something hadn't been improved.. i just reset it most of the time.. its a bit of a hassle yeah... and since it also freezes most times when you're reading messages or doin something else while listening to music, you sometimes have no choice but to choose doin one.. i suggest you follow coz its prone to data corruption it seems..[/SIZE][/FONT] :frown:
well if this is so why dont they upgrade it ?will there be an upgrade form the hand set like the sony ericsson or u have to finde a nokia agent ?
what a pitty first they take off the stereo bluetooth now this .. i bet soon u will see a n91i whit all that u dont have on this one when will all this stop ? after all we have paid a lot for this sexy hammer ....
Most likely software problems. Just take it local nokia dealer, and they should flash the software to latest build, and should minimise a lot of the
problems.
you can chech current software version by typing
*#0000#
mine is V1.10.025
22/04/06
there probably new version out now, it does make a lot of a difference.
With the pre-release software, it took over a minute to load a movie up!!
there still going to be some bugs that needs ironing out, but with any new product the first batch will be more error prone (software not hardware) then future iterations.
so best to just take it to nokia dealer, let them flash it, and should be alot better. Takes about a week for them to do it though!
Mine also froze a lot, someone recommended that i do the reset then afterwards do Full hard drive format, well after that it does not freeze alot, maybe once a day, much better than before
I have a friend with one, and already it is the second one. The first one, happened this frequent, until it did not work more. A problem in the hard disk was diagnosised. After to have been in the assistance technique 3 weeks, had given a new to it, that so far, no problem.
