Hi, I have a new Nokia N70 on O2. Planning to buy a 1 GB memory card. Pls suggest wht brand i should go for.
memory cards
Anything other than Kingston should be OK. See other threads on this board....
Steve
Just to add... make sure any card you get is of the Dual Voltage type. i.e. the card should be marked DV-RS-MMC, RS-DV-MMC or MMCMobile. A standard RS-MMC card will not work in the N70.
S.
