Since debranding and upgrading my Orange N70 I cannot switch to line 2 using the # shortcut? I have checked the Nokia documentation and it still details this as the correct method but all it does is toggle the silent profile.
Does anyone know the correct shortcut for line 2?
Thanks in advance.
Al.
Forgot to say I can switch using >Settings>Call>Line in use perfectly. Its just the shortcut that does not work......
Al
Err I was under the impression that you would have lost Line 2 functionality totally. Maybe the F/W upgrade just strips you of the shortcut change method. I think that the shortcut maybe lost for good but it's good to know the Line 2 functionality still works.
I don't even know what the latest Orange specific firmware for the N70 is but I think it's V3 from what I have read. Nobody (well none of the customer service monkeys) at Orange can give me a firm (sorry for the pun) answer on this.
S.
I can confirm line 2 works fine, its just the shortcut. This shortcut is a Nokia function not Orange.... All my previous Nokia phones worked like this, even with generic firmware....
All line 2 functionality works. Voicemail, voicemail indicator etc.
alpal wrote:I can confirm line 2 works fine, its just the shortcut. This shortcut is a Nokia function not Orange.... All my previous Nokia phones worked like this, even with generic firmware....All line 2 functionality works. Voicemail, voicemail indicator etc.
That's good to know that it still works. 😊 From what I have read I believe the standard Nokia shortcut for the # key has always been to switch to (and from) the silent profile. Only Orange handsets usually have the # key reserved for switching from Line1 to Line2.
S.
