Profimail now available for the N80
5 replies · 3,725 views · Started 26 May 2006
Fantastic. Profimail is now available for the N80 and it works a treat (so far). Even better, the file explorer has been embeded within the program, so no need for a separate program.
Good work by LoneyCatGames
chrsfrwll wrote:Fantastic. Profimail is now available for the N80 and it works a treat (so far). Even better, the file explorer has been embeded within the program, so no need for a separate program.
Preferred the old version myself with seperate file explorer, now I have to open profimail to browse for a file.
Also you can no longer browse system files with profiexplorer, which is a load of cack really😡
have they imposed limitations on the demo as I can't change the text size and various other things ? It always annoys me when developers put limitations on features in demos...why bother giving out a demo in the 1st place unless you give people full access to all the features
murrayalex wrote:have they imposed limitations on the demo as I can't change the text size and various other things ?
From what I understand, there are no limitations other than Time-expire. I can change the text size in my trial copy - go to the main top level screen, select Menu > Tools > Configuration (or just press 0) and the first option is to change Text Font size.
chrsfrwll wrote:From what I understand, there are no limitations other than Time-expire. I can change the text size in my trial copy - go to the main top level screen, select Menu > Tools > Configuration (or just press 0) and the first option is to change Text Font size.
I tried that but to no avail unfortunately...it seems stuck on the small font :con?
actually the font is working but it only applies to the text message, I was kinda hoping to get the icons a bit bigger...they're far too small. This programme to be honest I have found to be a disappointment, I 've come from using a palm treo 650 and I was using a programme called Snappermail for my email on it. Profimail is nowhere near in the same class as Snapper in terms of useability, configurability and customability..I was expecting (demanding) more from it:redface:
