I just bought nokia n80 and have some questions:
Is it possible to have timed profile defined:
e.g. at night silent
day general ?
Is there an opera browser available for n80 or you have to use mini opera?
The same question for pdf reader.
Is there an autolock feature?
Linux software similar to PC suite?
IM software (icq, msn, ...)
Does IM built in work with icq, msn, yahoo ....?
Tnx in advace.
G
Regarding IM software I use eMSN which is great. I only connect to MSN so don't know about other networks. I use it with the Nokia SU-8W BT keyboard which is also great.
[QUOTE=TheOne_]Hi,
day general ?
Well you cant have timed profiles and the auto lock is user defined
Opera is working on a version of the S60 browser for the N80. I think it is just a matter of optimizing the browser to the high screen resolution on the N80.
check this page occationally, to see when a version for the N80 will be ready:
http://www.opera.com/products/mobile/products/
icemanjimbo04 wrote:[QUOTE=TheOne_]Hi,I just bought nokia n80 and have some questions:
day general ?
Where you can define autolock?
As far as I know you can only lock phone by yourself clicking on yes after you close it.
Joar wrote:Opera is working on a version of the S60 browser for the N80. I think it is just a matter of optimizing the browser to the high screen resolution on the N80.
check this page occationally, to see when a version for the N80 will be ready:http://www.opera.com/products/mobile/products/
I've installed Opera for the N91 on my N80 and it works really well. Full screen, zooming, fit to screen width etc.. Looking good. Not sure what they are changing for the N80.
I'm using the N91 version of Opera as well, works fine. Don't think it's anywhere near as good as the new web browser from Nokia that's built in to the N80, brilliantly designed. Well, it would be if the phone didn't run out of available memory all the bloody time.... 😡
TheOne_ wrote:[QUOTE=icemanjimbo04]Where you can define autolock?
I was talking about the phone lock code not the keypad lock.
TheOne_ wrote:Hi,I just bought nokia n80 and have some questions:
day general ?
I will answer to this one myself 😉.
Found a program called Extended profiles which offers this functionallity.
http://shop.psiloc.com/en/Application,65542,Extended+Profiles+Pro,ScreenShots
The built in IM will not work with Yahoo etc unless your operator supports this (most don't at the moment).
There no PC Suite for Linux but you can find various utilities that may help you mount it. It shoudl work as a USB Mass Storage Device without any problem.
There are no timed profiles, Extended Profiles is not 3rd Edition compatiable (yet) so will not work.
A PDF reader is available on the Nokia site I believe.
someone else mentioned it in a thread but eMSN works really well for MSN messenger
