Hi All,
I recently bought a USB Bluetooth dongle (Bluesoleil 1.6.1.4 Release 050606) for my Nokia 6260.
I installed the Bluesoleil software and Nokia PC Suite 6.6.18 software on my PC (I'm running Win XP SP2).
I can successfully connect and transfer images/mp3 between my phone and PC through the basic services in IVT Bluesoleil software. But when I try to use PC Suite, it does not connect.
The steps I follow:
- Start PC Suite
- Click on "Get Connected"
- Select "Bluetooth connection"
- Select "Bluetooth(IVT Soleil)"
- It shows my phone in the "Detected devices list"
- I click next and it asks passcode, I enter "123" and click next.
- It says "You have the following connections available" AND the list is empty.
- The 'Next' tab is greyed out and I have only the 'Finish' button.
- After clicking finish, it makes no difference. It shows 'No phones connected'.
None of the applications in the PC Suite are able to find my phone.
I dont get the 'Bluetooth' icon in my Control Panel. Atleast is there any way by which I can pair my phone with PC Suite using the Microsoft Bluetooth?
Plz help.
