How Many Of you are Satisfy With N91?
13 replies · 6,664 views · Started 29 May 2006
been using n91 for about a month now, and i am quite satisfied with the phone. A firmware update is needed though.
No major problems encountered so far, only as follows:
1. Browsing using 'Web' sometines causes 'Out of Memory' error;
How to correct: Delete cookies and Empty cache
2. Assigning default number causes an "Application closed" error;
How to correct: Exit Contacts/Firmware Update
3. Music Library Details show wrong duration for the whole library;
How to correct: Firmware update
4. Gallery somewhat slow.
How to correct: Just wait for the database/thumbnails to be updated and your good.
5. Dust inside the screen.
How to correct: This is a design flaw. Bring it to Nokia Centre every week to have it cleaned and clear tape both sides of the screen (exterior).
6. Mac iSync support.
How to correct: Read this blog (link below) and see how to modify the metaclasses.plist
FIRMWARE VERSION:
V.1.00.028.14
29-03-06
RM-43
Original content from my blog: http://n91php.blogspot.com/
There still aren't that many N91 owners out there yet. The N80 seems to have captured more people's imagination.
Totally satisfied with my N91. No issues whatsoever! I like the build quality, Faster Menu(faster than my previous 6681 & N70), MP3 sound quality the most!!!! I will surely keep this phone for the next 2 years(atleast)... I just ordered Shure E4C headphones to go with this excellent phone, can't wait to receive it 😊
157 pounds for bloody head phones christ.. yep pleased with mine sound is great even with the nokia head phones .. wish ther was more apps that work with it only time will sort that one out
well pleased with it
I just need apps for it. shoulda been backwards compatible this s60 v3 nonsense.
Although I'm chuffed my phones faster than the n70 muhahahahhaaaaa:redface:
i have been useing N91 for a week now .. >> the only anoying thing is that i still cant find good and compatable themes and applications. otherwise >> everything is ok
Working brilliant.
Only problem is that the
Album art feature is pretty useless when syncing with Windows Media Player, as you need to manually link the pictures. Why could they not add support for automatic retrieval?
For good themes try the the official themes for Nokia 3250 off the nokia.com website, they work on the N91 as well without any problems.
plus
http://n91.wordontheblog.com/
provides latest software and info for N91,woth checking out
What are you supposed to do if you don't live near a Nokia Centre? From what I can gather from the website, the only one in the us right now is in Chicago.
Until it started freezing on me. Clearly in need of a firmware update, but not sure yet how to do that as I live in the States and as mentioned on a previous post the only Nokia Centre is in Chicago...
I'm back to the N70 for now as my N91 does not work currently after a few minutes of being on. 😡
gtdmouse wrote:What are you supposed to do if you don't live near a Nokia Centre? From what I can gather from the website, the only one in the us right now is in Chicago.
Too bad.. i dont know really, i tried to use a vacuum cleaner but to no avail. Fortunately, Nokia Centre is just walking distance from my office, so i get to have it cleaned at least on a weekly basis.
I already saw original parts for sale here already in the Philippines, i still have to check though the front cover, if still has that 'gap' otherwise i might get the new cover.
