I've been having loads and loads of problems with my N80, just wondering if anyone has been having the same trouble?
Bought it on 16th of may, and had to wait till 23rd until its sim was activated.
Firmware: V 3.0614.0.3 - 11-04-2006 - 42.04 (Vodafone Phones4U)
In the mean time I still used it loads, as a camera, mp3 player etc....
During this period the only problems were:
- Never did get Ad-Hoc WiFi working. Had to connect to an infrastructure instead... this is not how I wished to use it!
- Out of the box, with NO other applications running, Snakes would load up, and some weird number entry box flashes up loads of times really quick and crashes. On the rare occasions when Snakes DOES play, it often crashes after 5 mins.
- One morning I was taking a few photos, and when loading into the gallery to view them, the phone crashed and turned off. When it back on, I could not access the memory card. It just froze the phone when trying.
So I put it into my PC. Half of my files where corrupt... which pissed me off. So I backed up the good files, and tried to format the memory card. Failed. Tried to delete all the data on the memory card, most of it deleted but some failed. Tried to format again... failed. Had to do a Quick Format in the end, followed by a Normal format which worked. Then I put it back in Phone and formatted with File system, and copied data back to it. It has been fine since then, but why did it corrupt?? I ALWAYS *remove memory card* before pulling the card out.
- Severe memory problems like most other people have been experiencing...
- Extremely pissed off when I found my library of S60 2nd edition software doesn�t work... had no warning of this!!!
Sim card has now been activated.......
- Now this really annoyed me, The Web Browser. When im using it at home, I use a WiFi access point called HOME. This is saved in the phone and I set it as default. But when I�m out and about, and I want to use Vodafone�s web, I have to manually go to settings and change the default to Vodafone. If I set the option to ASK EVERY TIME, when it asks me, all I can see is "Scan for WiFi networks." It doesn�t list any 3G/GPRS connections... GRRRRRR. Is this just my phone? Because I swear when I first had it, it listed ALL.
Here comes the annoying stuff.
- When im calling someone, 90% of my calls so far have CUT OFF. Within about 12 seconds of talking fine, suddenly the other person can not hear me, but I can hear them. Then it says "Disconnected"
- After that happens I can�t dial out or receive a call for about 30 seconds. Incoming calls also drop, which is a right pain in the arse!!
- Video calls..... If I call someone else, it starts working, I can see my own camera, it rings the other end... but no matter what phone or network im ringing, the other phone *thinks* its a voice call... and receives a loud BEEEEEEEEEEEEEEP instead of the video. When in Phones4U Store trying to sort this, he tried video calling another phone on same network, Vodafone, it says on screen... "Not supported by network"
Incoming video calls work fine...... WHY DOES IT NOT WORKL!??! ARRRGHHH
- Vodafone Live.... the soft key brings up the browser.. Connects to the internet... and then returns "Server Busy" or "Bad Gateway".... but if I browse away from Vodafone�s websites, to google or bbc, it works fine.. and quite fast...
In Phones4U Store they tried placing my sim in brand new N80, it solved VodaLive problem, but video calls got worse, and voice calls i don�t think we tested. After spending about an hour in store speaking to Vodafone support they said it�s a Faulty SIM CARD...... (*Cough*... *Bollocks*)
Well my new sim card arrived. Put it in, they said it would be activated INSTANTLY.
An hour later, still says "Sim registration Failed"
So I pop old sim in, and call Voda and get them to do it.
Once it�s done im back up and running....
Video calls.... Still fucked.
Voda Live... still wont load.
Voice Calls..... Much Much WORSE. Now getting un-bearable... have to repeat call people so many times during a conversation. (When phone Vodafone support, I had to start ALL AGAIN FOUR TIMES because it cut off. each time getting more pissed off, the 4th time she agreed to ring ME back if it cuts off... (Which it didn�t for the first time ever..)
So anyway... im going in store today to get a new handset see if it fixes these problems....
Anybody had similar troubles??? :icon4:
