Is there a fast way to remove your send or received mail? I don't see an option for that then just remove them one by one..
Since I get and send alot of sms it's really tiresome...
Would be nice to see a 'clear list' option.
removing in/outcoming mail question
You can 'Mark'->'Mark All' then 'Delete'
Unfortunately not... the quickest way seems to be by doing Mark All -> Delete... not exactly the most efficient of things, is it?
mm..not really no.. there is always 1 or 2 sms i want to keep..
oh well..the dissadvantages or having the newest technology 😛
thanx
You could always open the keypad, and hit the "c" key, then hit "yes", its a little bit quicker than going through the menus.
Andy
How lazy are you people? :P
[quote="Lord-X"]How lazy are you people? :P[/quote]
too lazy to type a reply.
oh
bugger.
what you can do is mark one at a time all you have to delete and then go to options and select delete. it doesnt have to be a "mark all" thing. i think this is the fastest most effcient way of going about it.
press and hold ABC button and scroll down the joystick and will mark the files, if a message that is mark that you dont want to mark, just unhold the ABC then press and hold ABC again and scroll up to the mark message
[quote="mjsee"]press and hold ABC button and scroll down the joystick and will mark the files, if a message that is mark that you dont want to mark, just unhold the ABC then press and hold ABC again and scroll up to the mark message[/quote]
yep yep i think this is the best way if u want to keep some of the msges
another tipp.
select all as marked,
then move to the one u want to unmark:
press abc-button and then press the joystick:
so it is unmarked 😉
S�mi
