Hello,
Is anybody using gcalsync software on n80?
It doesn't work on my phone - problems with connction.
G
Hello,
G
TheOne_ wrote:Hello,Is anybody using gcalsync software on n80?
It doesn't work on my phone - problems with connction.G
Anybody?
Can somebody try to connect to Google Calendar.
Software can be dl from:
http://www.gcalsync.com/
Thanks for flagging this program up! Should be great when it gets working.
If you look at the website, it's quite hard to see but in the 'Known Bugs' section there is the following text:
"IOException: HTTP-Version Mismatch, Native Error-36 reported in Nokia S60 phones (N70, N80, E60?). I would like feedback on what "Test" prints out in this case, specifically whether HTTP fails or if it just affects HTTPS. "
I've sent him my log files and the results of the tests on my N80.
Apparently he's working on a fix and it should be ready quite soon. I'll keep you posted if I hear anything.
Ok, it's working brilliantly now. Go over there and check it out!
[SIZE="1"]
-but read the 'known bugs' section, though, before you complain about the time being out by an hour... [/SIZE] 🙄
I get the same java error. I hope he can fix it as steering well clear of Outlook was my main reason for getting a phone not running Windows mobile!
I have also sent him logs. It seems that error was corrected and now it works fine.
