please help me out....
2 replies · 1,353 views · Started 31 May 2006
Hi to all,
Actually i have problme with synchronisation of my 9300 set with my notebook. I have recently installed 6.6.16 vesrion of NOKIA PC Suit. When i do start synchronisation this message occurs on my screen " Oraniser 5.0/6.0, unable to load organiser. The Organizer API file (ORGAPI32.DLL), or its components, could not be loaded" .
I have reinstall this software & again same problem is comming. Is this beacuse i am using new PC Suit? If i install the old version then i could not connect the my notebook to net threw blue tooth.
SO i want the PC suit which connects to net threw blue tooth as well as do successful synchronisation and ofcourse ohter things too.
Your kind help would be ease of my tension.
Thanks .... 😊
ALA
Attachments: message.JPG
allauddin wrote:Hi to all,
ALA
Sounds more like you've got PC problems. Is "Organiser" Lotus Organiser? Also, 6.6.16 is VERY old now, at least two major updates out of date.
Try installing the very latest version from http://europe.nokia.com/nokia/0,,72014,00.html - if that doesn't work, it's probably time to clean out your Windows installation and rebuild it with fresh app installs.
Does this help you?
Steve Litchfield
hey buddy... i finally did format my laptop.... now can do synchronisation...
thanks ur help... i really do appriciate it.. because it was only your response out of 171.
Thanks again..
With Regards,
ALA
