How to remove hotspot finder?
5 replies · 4,165 views · Started 31 May 2006
It doesn't appear in the application manager. The trial period has expired and I don't feel like having it on my 9300i taking up space.
Picsell attachment viewer is on the same boat, I can't find where to uninstall it.
Any help would be apreciated, thanks.
--Qin
Qin wrote:It doesn't appear in the application manager. The trial period has expired and I don't feel like having it on my 9300i taking up space.
--Qin
Are you sure it's not listed under 'PsiLoc xxxx', the people who made it?
For most software that falls between the cracks of the installation system, enable viewing of the System folder in File manager and then manually zap the appropriate \System\Apps\HotSpot (or whatever it's called) folder.
Does this help?
Steve
Yes, I'm sure it's not listed as "Psiloc whats-his-name".
How can I enable viewing of the system folder?
Thanks.
--Qin
I had the same problem. I found a solution. I both reinstalled the applications on Memory card and uninstalled them again. that way they were uninstalled and dissapeared.
Select filemanager, then hit the menu button.
View > Show all files (tagged)
Tools > Settings > Show system directory > Yes
I think the apps are only on the memory card. When removing the MMC the icons do not appear on the desktop.
With the filemanager go to the memorycard, select system, apps and remove PicselViewer and wifif dirs.
