Reset custom dictionary
4 replies · 6,870 views · Started 01 June 2006
You can do it on older models by deleting the C:\System\Data\PTIT9UDB0f.dat file using a program like FExplorer, but I don't think there are any file managers for the N80 that can read the "System" folder at the moment.
mcsleazycrisps wrote:You can do it on older models by deleting the C:\System\Data\PTIT9UDB0f.dat file using a program like FExplorer, but I don't think there are any file managers for the N80 that can read the "System" folder at the moment.
There is not fxexplorer but some other its also Freeware and its name is Sexplorer.
Looks like it has changed its location.
I just had a look and it looks like its been placed:
C:\system\Data\Predic
And mine is named: 101F8615_F.dat
I checked this file and it def contains custom words.
Rene
Hi all,
my n80 is bought in Singapore. and the phone has an in built dictionary which was working. but recently when i wanted to use the app. again. the phone keep prompting me to install missing word database.
i tried to install another dict app. frm SlovoEd. but similar prompt appear.
Anybody Knows what's happening?
Any remedies from anyone?
Deityrealm
