help pls!!! outbox msg cant be deleted
8 replies · 3,245 views · Started 26 November 2002
can any one know how to erase a msg in the outbox? what happen is as i was sending a msg my fone turned off(batt empty) then when i turned it on an icon of the outbox was visible,so i look at the outbox and ther it was 😞 , no sending or deffered remarks, help pls tnx :-?
Wish i could help! My friend has the same problem. Message icon still up there and the message is stuck
My friend tried switching it off then on again, but still nothing happend.
Maybe you can delete it using SeleQ?
This is a Hardreset,and u will loose all your datas...
better try a backup from pc to phone.
(It only works,if u not already do make a backup from 76 to pc with this error.)
PS:i copy already a longtime a working backup-folder intoo another directory,so i will always have a easy way to repair an error
S�mi
[quote="😊"]It's *#7370# correct me if i'm wrong, this code is getting confusing![/quote]
that code is correct, i have formatted my phone over 20 times so far, i should know 😃
😊, Shadow, S�mi, 555, seanmiguel
tnx, it works, its just that simple, it took me less than a minute everythings back to normal tnx again 😃
