Can�t see videos on my Nokia E61
5 replies · 5,905 views · Started 02 June 2006
I have sent mpeg4 videos to my E61 via bluetooth, and when opening the message containing it, i get a message saying "unknown file format". Anyone knows what is happening?
Txs a lot
You need to make sure you have the MP4 video in the right codec. You can either re-encode the video or try SmartMovie which has a greater range of cdecs supported.
vcasqu wrote:I have sent mpeg4 videos to my E61 via bluetooth, and when opening the message containing it, i get a message saying "unknown file format". Anyone knows what is happening?
Txs a lot
It may be that the MPEG-4 videos are designed for larger screens and faster processors. MP4-compliant mobile hardware tends to have a few upper limits on bitrate and screen resolution, for example.
Try my MP4-encoded video podcast, http://3lib.ukonline.co.uk/sshow/
Steve
Incidentally, the video podcasts (those newer ones with .mp4 file extension) on the Smartphones Show are the only ones that I was able to view on the full resolution of E61. I was not able to produce such material by myself (with FFMpegX on Mac). Steve (or somebody), could you reveal how to do it?
The free conveter, Super at http://www.erightsoft.net/SupCk2.html will do the job nicely.
Select Mpeg4 for container and compression, 320x240 for size and a bitrate around 280-300 Kb/s for smooth video.
Smartmovie from Lonelycatgames is another (not free) tool that I use most often. It is fast and easy and comes with both phone divX player and PC based converter.
It can convert DVD movies as well, although you need a decoder like anydvd to open encrypted DVD's
Regards
Michael
teroT wrote:Incidentally, the video podcasts (those newer ones with .mp4 file extension) on the Smartphones Show are the only ones that I was able to view on the full resolution of E61. I was not able to produce such material by myself (with FFMpegX on Mac). Steve (or somebody), could you reveal how to do it?
I use Quicktime Pro:
"MPEG-4-improved" encoded Quicktime MOV file, 300kbps, 320 by 240
Sound AAC-LC, 22KHz, 64kbps or similar
Although the exact settings aren't that important. What IS important is not to use a wacky MPEG-4 variant and not to push the frame size or bitrates too high, I suspect.
Steve Litchfield
