shifting messages from one memory card to another
1 replies · 1,454 views · Started 03 June 2006
Hi
I have a nokia 6600 fone in which i have saved the sms memory as memory card, however i`am planning to buy a new cell, but i need all these messages which are in the memory card, is there anyway i can transfer all the messages from this memory card to another card, i have tried copying files using Fexplorer(system>mail>....1001s>0, 1 ) but of no use .is there any way..
plz revert ASAP
Regardz
Abrar
theabrar wrote:Hi
plz revert ASAP
Regardz
Abrar
What phone will you be getting to replace the 6600? Some of the latest phones like the N70 have a transfer application. Otherwise if your new phone has a compatible memory card you could try...
Copying the mail to the phone memory of the old phone, then inserting the new memory card and copying the messages back across.
Kinda depends on your replacement handset though.
S.
