PC Sync fails with Outlook on XP
1 replies · 6,517 views · Started 03 June 2006
Hello,
I've just bought my N80. Now trying to sync my outlook calendar. contacts and tasks with my phone using PC Sync. Can't get it working...
- I've got XP with PC suite 6.80.21 connected using USB cable
- My PC suite works well, I can see all files and can do backups etc
Once I setup PC Sync, I can select the phone, but once selecting the settings button nothing happens....
Does anyone else have an idea, I've tried reinstalling, different PC suite versions and am stuck now.
Chris
I'm having exactly the same problem. pc suite works fine but when i try to sync Nokia pc sync says:
PC Sync information.
PC Sync has encountered a problem and has terminated the synchronisation.
and the phone says
system error
