Hi all,
This problem is a wired one and i don't know if anyone has had the same problem. basically i was messing around in fexplorer and i must have done something for this problem to happen.
After looking in the fexplorer I reset the phone and the next thing i knew that a white screen comes up saying "loading...". However if you hold the menu key on the left a little window still comes up where you select an application. In my case the telephone icon is there so i'd be using that as my main screen.
So basically the menu i would usually have is the one where the menu is on the left of the screen, that will not open. I dont know if this theme studio will solve the problem. The phone still works and i can access the main menu like usual but not that front screen menu where there is a bar on the left.
Any one got any ideas?
Bazza :con?
