Hello
It`s me again...
I have problem with Sendo X. Cell can`t find a net (operator)...
Now i don`t know what to do ... Tomorrow i go to service but propobly they don`t rapier Sendo X (if you know how to do that in pro service tell me and i relay them wath they must to do).
Please fo a fast replay !!
There's various things you need to do. Firstly, make sure you reflash the phone with the latest firmware and do a complete re-format of the phone's memory (hold down the 5 key while you turn the phone on to do this)
Then make sure the SIM contacts are clean on the phone, and make sure your SIM card itself is clean.
If this doesn't resolve the issue, you then need to check the phone and SIM card by trying a different SIM card in your X, and trying your SIM card in a different phone. This will tell you whether the phone or the SIM is the problem.
If the phone still can't find any networks, you'll need to open it up and check the connectors to the phone's aerial. These connectors are under the phone's motherboard, which will have to be removed to check them. They should make a good connection between the aerial (which is hidden above the camera module on the back of the phone) and the phone's motherboard.
Pls My Sendo X Is Showing Sim Card Rejected.can Any One Help
shamyboy wrote:Pls My Sendo X Is Showing Sim Card Rejected.can Any One Help
We need more information to help diagnose this problem.
