N80 shots from Biggin Hill air show held in kent yesterday (04.06.2006) 50% reduced in size, I think it is pretty good picture quality taken on a clear day :icon14:
[SIZE="5"]These are taken using the zoom mode on the N80....[/SIZE]
[SIZE="5"]A small mp4 video taken, this is in 50% zoom mode[/SIZE]
Those pix look good.
Certainly better than what I am getting with my N80?????
Have you sharpened them up?
willbrady wrote:Those pix look good.
Yea My N80 pics are crap in comparison, quite blury with haylo's around some bright images, also very faint horizontal lines running accross the picture..I am really dissapointed, I have a 6 year old 3Mpix sony cam that gives some of the best pictures I have..far better than what I can acheive.
But the pics here look real clear and good,
What settings are you using ?
All image settings were left on auto, photo shop was used to reduced the size of the pics and auto contrast was all that was used on these photos.
Latest fw also on the phone if that makes a difference ??
Is there any way to transfer pictures and video over wifi instaed of using the cable or bluetooth ??
How do you insert images into these posts ??
I want to insert a couple photo's I took to show how awfull my camera is
If you have the images hosted somewhere use (but no spaces)
[ img ]http://www.imager.comimager.jpg[ /img ]Otherwsie try doing them as attachements.
Ok Thanks Rafe
well here are my pictures, just made smaller but as you can see the quality is awfull, in fact they look better being smaller..I did read that there are different lenses on some models of N80..I have 4.7mm 1:3.5 dont know if this makes a difference.
This is another photo from yesterday untouched straight from the memory card.
Do you have any shots taken indoors ?
Just taken this for you matey................................
You can see quite alot of noise in the picture quality when using indoors but most mobile phones show noise indoors.
I took this when i was driving and stopped at some lights.
Ok..I am feeling a little better that it maybe the same quality for all indoor photo's, its obviously an insufficient light problem as the flash is really inadequate, a friend of mine has a 750i with a clip on flash which is really great, does anybody know if this is available for the N80 or other nokia phones ?
Here's a couple of images that I took to test the focus and dynamic range of my N80, which is pretty good. Also, I took the liberty of running the desktop image through Noise Ninja in Photosop CS and resizing & sharpening. Looks good to me. N80 images can look very good with some post processing and the noise in low light images can be removed quite well.
Simon
