2GB RS-MMC compatible with Nokia 6682?
5 replies · 5,285 views · Started 05 June 2006
well i hope my 6630 supports becoz m planning to upgrade my 256mb card soon,by the way the sofware part of 6680 is somewat same as 6630..
I see that 30 people have viewed and no answer. I guess I will have to give Nokia a call. I will post here to let everyone know what I found out.
Thanks,
Derek Basch
For the record, and for all those other folks who found this thread while Googling for an answer to this question (like I did)
The 2GB RS-MMC cards work. Or at least mine has for the past six hours or so, and the phone reports proper memory space and whatnot. No noticeable slow down on the phone itself, either. You should probably know that the phone is pretty new, so it's still fairly empty.
Back to the details I do know: specifically the 2GB MMC Mobile cards from Kingston.
Kingston Part # MMCM/2GB
http://www.kingston.com/flash/mmc_mobile.asp?id=2
Also, to those who are new to the phone, be aware that not all RS-MMC / MMC Mobile cards will work. The primary issue is the dual voltage (the Kingston is 1.8V / 3.3V). Anyway, I purchased mine from ZipZoomFly and am happy so far.
[oh, and apologies to the regulars for the bumpage of an old thread. 😃 ]
Thanks this was alot of help, im going to buy one for my 6680 now. you can get them for less than AU$50 from ebay.com.au
