Hiya
App. Closed Start up!
I get that message on start up and hav no option but to go OK -
Menu button doesnt do anything- only things I can do is create new txt, camera & use the toggles to check contacts.
So I cant check incoming texts - No pop up saying one new text only the little envolope in top corner.
Does anyone have any idea how to fix this error.....
Lolz wrote:HiyaApp. Closed Start up!
for me, need to format again the phone, enter *#7370#,
phone back to 'virgin'
ameiruddin wrote:for me, need to format again the phone, enter *#7370#,
did this work?
I have the same problem and it is very annoying...I get App Closed Screensaver...and a lot of other problems like hanging while trying to open the Gallery etc...Please let me know if this works.
Kesava wrote:did this work?
:icon14: try your luck...i hv done it before.....otherwise get the malware disinfector, use it...... uninstall the apps or the screensaver
