Importing group data into Contacts
1 replies · 2,153 views · Started 06 June 2006
I suspect that this question has been posed before but, as a newbie, I need to know how I import the group data for each contact entry into the N70. Basically I bought the phone on the basis that I could do this but after some testing it appears that the Symbian OS doesn't support group data import or export.
Since I need to import a large number of entries, all with specific groups, hand linking to a group is not an option!
Does anyone out there know of a workaround?
I run both Mac OSX (platform of choice) and PC Windows XP.
Hmmm....not sure where you're importing from but I used Contacts Manager 1.04 to import contacts with group data into my n70. All group data came through fine.
