Screen protectors...
9 replies · 2,265 views · Started 26 November 2002
Well, I've had my 7650 for a few months now and I've finally been forced to remove the protective piece of clear film Nokia use to protect the display bezel during assembly.
Now, where can I get a replacement from? I'm paranoid about scratching the bezel and the look of the display deteriating because of scratches. I see this protective film in much the same way F1 racing drivers have a load of removable films on their helmet visors...
Anyways, quit the laughing at me 😃 I really do want to put a cover back on the bezel to keep it fresh looking 😊
Are these available from Nokia, or, are there 3rd party covers available?
Jason
www.sugarline.com
i don't understand y u were forced to removed the screen protection?
im unsure if u can buy a spare one of those, but i think even if u could it would be very hard to put on the screen properly without leaving "bubbles".
...well, several months of the phone being slid in and out of my jeans pocket had left that lil silvery bit with no adhesive very dog-eared, to the point it really did look very tatty, so I removed the film 😞
Getting a new one on without bubbles is a piece of cake, you just need a bit of sponge and a small amount of patience 😉
Jason
www.sugarline.com
Im pretty sure you can get a replacement in your local Nokia Care Centers, and you should do it quickly. I remember the time i removed mine and dang it! i scratched the screen butt ugly! :x but anyways my phone is ok now coz i git the casing replaced. 😃
If you cannot get it from nokia. Why not try your local PDA shop. I'm pretty sure they have all kinds of protector for the PDA. Just be careful in cutting the protector because it's not exactly the same size as youe phones screen. 😃
... yeah, first port of call methinks will be Club Nokia, see if they can help.
Thanks for your ideas 8)
Jason
www.sugarline.com
that ain't a problem for me cuz well sell them screen protectors for PDA's ! it takes time and patience to put it back again! cutting it is not that hard!
I bought some PDA protectors from Maplin, at 6.99 you get around 14 sheets inside which can make u 28 7650 protectors.
[quote="Anonymous"]I bought some PDA protectors from Maplin, at 6.99 you get around 14 sheets inside which can make u 28 7650 protectors.[/quote]
Ah most excellent, looks like I'll be getting some on Friday when I next pop into Maplins in Cardiff (my weekly visit there :-? )
