Guys,
have any one of tested 2GB miniSD Ultra II card on N80...Will it give any problems or will it work perfectly fine. The only difference b/n mini SD and mini SD Ultra II is the transfer speed. On Ultra II the speed of transfer is arnd 10 Mbps. So let me know if anyone of you have tried using this card with N80. Also let me know of the access speed and others problems if any....
thanks,
Vince
I bought a 2gb mini SD card from SANDISK. Works fine. Lots of space for pictures and tunes and software when it becomes available.
J.
Yea I'm using the Sandisk 2GB Ultra II. Works a treat no problems, seek and find speeds for mp3 and video files is very good. I recommend it alot can get it on the net for around £50 well worth it if u get smartmovie, listen to a lot of mp3s, or wanna take a lot of pics
Thanks guys......have already place my order....:icon14:
