My phone keeps coming up with 'Low Memory' or similar messages i.e. delete some data, not enough memory
It also keeps coming up with the flashing messages symbol, indicating too many messages
When I restart the phone it momentarily fixes it but both problems come back. I've closed all the open applications down and the memory problem still comes back.
I've also had hundreds more texts in my inbox without a problem. I've recently installed Aces Texas Hold'em Poker, could that have caused these problems? Does anyone know what might be wrong?
what phone are you using?
benp1 wrote:I've also had hundreds more texts in my inbox without a problem. I've recently installed Aces Texas Hold'em Poker, could that have caused these problems? Does anyone know what might be wrong?
I guess the simplest way to find out is to uninstall Hold'em and see if it goes back to normal. :tongue:
If you've installed ATHP to the internal memory, maybe it might help if you removed it and installed it to a memory card instead?
I did put in on my phone memory, but thats because I'm going to change my memory card soon and I didn't want to lose it.
I can't delete it because I have no way of putting it back on without paying for it.
Thanks for your help, has anyone else got any ideas?
