N91 Question-disable cable connection
1 replies · 2,101 views · Started 08 June 2006
Hello
i�m a new N91 user. My question is: when i have my N91 connected to PC by USB cable, how can i disconnect it? just by taking the cable off? or there is any procedure i must to do, to disconnect the phone safely?
thanks
Yes you can just remove the cable. You might want to use windows built in remove tools when in usb mass storage moe.
