sHow to store file , received from Bluetooth
4 replies · 2,327 views · Started 08 June 2006
When I am sending some files to my 6630 from PC using Bluetoth,
then files are availabe in Inbox.
How I can move these files to my own folders, not in mail.
I have tried message store but its not showing bluetooth messages
its showing all other.
How can do that.
Thanks,
BT
bengaltiger wrote:Hi,
How can do that.
Thanks,
BT
use any explorer and find the folder "system\mail' and try opening the subfolder and u will find ur files u sent to ur mobile. just copy it to the location u wanna and delete the msg from ur inbox
:icon14: U can use Fexplorer..the INBOX option of Fexplorer let u c all files received by BT,IR or even by MMS:tongue:
all u have to do is copy and paste your files wer ever u want😊
Whatever the Phone Model.. Fexplorer is the program you gonna use.. find all the files in e:/system/mail...
regards,
Amitabh Bhandari
