Orb problems
4 replies · 3,332 views · Started 08 June 2006
I managed to set up Orb and even stream a video to my N80 this morning. However I've tried now and I click on the "Play" button in the web browser to start the stream. The little "download" window pops up and then RealPlayer launches. It's now aasking me to define an access point first. It didn't do this this morning when it worked, it just opened real player automatically.
Any suggestions? (I'm using WiFi, but the access point varies depending where I am)
mcsleazycrisps wrote:I managed to set up Orb and even stream a video to my N80 this morning. However I've tried now and I click on the "Play" button in the web browser to start the stream. The little "download" window pops up and then RealPlayer launches. It's now aasking me to define an access point first. It didn't do this this morning when it worked, it just opened real player automatically.
I read this on the orb forum
If anyone else wants to stream to their N80, you gotta open real player first, then go to Options>settings>connection>network and change the default access point to the one you're using (if WLAN). Then you can browse and use the stream normally.
Make sure your firewalls on your PC (and router) are all set correctly to let orb stream
I also found the N80 is a little like M$ window .. if it starts playing up, turn it off and restart it
Thanks for that mate - bit of a bind having to change the access point in real player every time. It's weird why it worked first time without setting up the access point, but then failed later on.
I tried rebooting the phone but the same thing. I've set it all up at home and is working great. It's kinda cool how you can stream a webcam with sound over the net and see what's going on!
mcsleazycrisps wrote:Thanks for that mate - bit of a bind having to change the access point in real player every time. It's weird why it worked first time without setting up the access point, but then failed later on.
yea I use that alot, I have builders in at the moment and like to keep an eye on them 😊...caught them skyving a couple of times and they still dont know how I found out 😊, but since I gave them a bolloking they have been working very hard 😊..
