cant play wav!!
6 replies · 2,165 views · Started 03 December 2002
can anybody try this wav file and tell me does it work on ur 7650 ??
keep on giving me general system error followed by recorder error
[quote="555"]i have heard that u can't play stereo wavs
that could be the problem[/quote]
Absolutely true.
is this the "master-i-have-mail-for-you wav???" i havent listend to the attached file. if it is there are some of these files in the net that dont work. you can check this out for more wav tones u might like.
http://www.a1freesoundeffects.com/
also had the same problem with one wav file! but the others were great!! maybe becuz it's stereo or something! cuz i checked the file and i thought it was a joint stereo or something! don't know anymore!!
yep it is the master i have mail for you wav file ....
thanks ... i'd search for another same file on some other side ... and it work .... however ... there are few kb of different in the file sizes ...
but still coulnt determine whats the problem ....
