mp3 as alarm tone in N70?
3 replies · 2,699 views · Started 12 June 2006
I found out myself. I simply copied the mp3 file to "Sound clips\Digital Sounds" directory. Then it was available to select from "Clock->Settings->Clock Alarm tone".
Earlier, I had kept this mp3 in a directory created by me. Looks like only if we keep the mp3 in "Sound clips\Digital Sounds" folder, it will be available for Clock Alarm tone.
Cheers!
Siva
sivak wrote:I found out myself. I simply copied the mp3 file to "Sound clips\Digital Sounds" directory. Then it was available to select from "Clock->Settings->Clock Alarm tone".
Cheers!
Siva
You sould'nt even have to do that,i can select any tone as my alarm tone:tongue:
You can also use OggPlay as an alarm clock. That way you can use any selection of mp3s or oggs to get you out of bed in the morning 😊
