N80 theme uninstall
1 replies · 3,234 views · Started 12 June 2006
after reading a previous thread i downloaded and theme for the nokia n80. installed it and it worked. but now i can't seem to delete it. it was easy to do so on my previous phone
but i cant remove it from the nokia n80
i go to app manager and try to remove it (options > remove) and it just says unable to remove.
help me!!!!!
1. Make sure you select a theme different to the one you wish to uninstall
2. Turn Phone off the on
3. Goto App manager and delete the theme.
