N80 browser problem
4 replies · 3,734 views · Started 12 June 2006
My N80 will be restarted when I use it to access any web site in chinese language via wifi.
Please help................................................
cmsjkung wrote:My N80 will be restarted when I use it to access any web site in chinese language via wifi.
Tell me what website you try to open and I will give it a go to see if I have same problem.
did you upgrade your firmware to the latest version, some people had browser problems with the old firmware.
check with *#0000#
i saw your post and tried use mine to surf yahoo china.
on my first try, it worked initially, but as i tried fiddling with the font size, my phone turned white too and restarted itself. Worse it didn't register the existence of my memory card in the phone.
On my second try, i surf the same site and left it there until the page is done loading. i selected 1 of the hyperl;inks and it work. the phone restarted itself again when i tried decreasing the font size.
so i conclude that your firmware and mine are the old ones. My firmware is:
V 3.0614.0.3
11-04-2006
RM-92
Nokia N80 (49.01)
