From their site:
AutoStart application is a simple but useful tool for every Nokia 7650/ 3650 user, which gives a similar functionality to the Windows Autostart folder. Every time you switch your phone on, selected applications will be started automatically for you.
After the installation you can open the AutoStart application. You will see an empty list at the beginning. By choosing appropriate option from Options menu or clicking the joystick, you can add any application installed on your device (the list of available applications will appear on the screen). This way you can create a list of applications you would like to start every time you switch your Nokia 7650/3650 on. The applications will be started in the order they are placed on the list. Obviously, any item can be deleted from the list using corresponding menu option or Cancel key.
to get, go here:
http://www.psiloc.com/nokia/eng/autostartS60/index.html
