This may be a bit peripheral to this discussion but any suggestions most welcome.
I'm attempting to set up opensync to connect my m a925 to a sunbird calendar for syncing. One of the things I need to find to set up the sunbird-sync plugin is something called my
usb obex interface.
I've followed instructions that say to connect the phone to the computer by the usb cable and issue the command
sudo syncml-obex-client -u
and it should show me the interfaces, however it gives back nothing as
Found 0 USB OBEX interfaces
Use '-u interface_number' to connect
If anyone knows can you tell me if I'm missing something to do with obex on the computer, or alternatively something on the phone is set incorrectly or missing, or last alternative is that this phone simply can not do this?
Thanks a bunch
Jim
lsusb gives
lsusb
Bus 005 Device 005: ID 413c:9001 Dell Computer Corp.
Bus 005 Device 002: ID 413c:a005 Dell Computer Corp.
Bus 005 Device 001: ID 0000:0000
Bus 001 Device 011: ID 22b8:4002 Motorola PCS A920/A925 UMTS Phone
Bus 001 Device 001: ID 0000:0000
Bus 004 Device 001: ID 0000:0000
Bus 003 Device 003: ID 046d:c505 Logitech, Inc. Cordless Mouse+Keyboard Receiver
Bus 003 Device 002: ID 0451:2046 Texas Instruments, Inc. TUSB2046 Hub
Bus 003 Device 001: ID 0000:0000
Bus 002 Device 002: ID 413c:8103 Dell Computer Corp. Wireless 350 Bluetooth
Bus 002 Device 001: ID 0000:0000
